I keep getting the message "Objects in this class cannot be updated outside of an edit session." Can anyone tell me what I'm doing wrong?
def CreateRelationshipClasses(self): # Set workspace env.workspace = "C:\Users\jsparfitt\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\uppco@neptune.sde" try: # Go through list of relationship classes defined in variables.py and create them in file gdb for rc in relClassList: WriteToReport("Building " + rc["relClassName"] + " relationship class ...") if (rc["addCalcKeyFields"]): # ESRI BUG: Need to add string field to hold globalid values for both feature class and table # Relationship classes between globalid and guid fields fail in Python WriteToReport("Adding " + rc["originPrimaryKey"] + " field to " + rc["originTable"] + " ...") arcpy.AddField_management(rc["originTable"], rc["originPrimaryKey"], "TEXT", "", "", 50) WriteToReport("Adding " + rc["originForeignKey"] + " field to " + rc["destinationTable"] + " ...") arcpy.AddField_management(rc["destinationTable"], rc["originForeignKey"], "TEXT", "", "", 50) WriteToReport("Calculating " + rc["originPrimaryKey"] + " field values ...") # Start an edit session. Must provide the worksapce. edit = arcpy.da.Editor(env.workspace) # Edit session is started without an undo/redo stack for versioned data # (for second argument, use False for unversioned data) edit.startEditing(False, True) arcpy.CalculateField_management(rc["originTable"], rc["originPrimaryKey"], "!" + rc["realPrimaryKey"] + "!", "PYTHON") WriteToReport("Calculating " + rc["originForeignKey"] + " field values ...") edit.CalculateField_management(rc["destinationTable"], rc["originForeignKey"], "!" + rc["realForeignKey"] + "!", "PYTHON") # Create relationship class arcpy.CreateRelationshipClass_management(rc["originTable"], rc["destinationTable"], rc["relClassName"], rc["relClassType"], rc["forwardLabel"], rc["backwardLabel"], rc["msgDirection"], rc["cardinality"], rc["attributed"], rc["originPrimaryKey"], rc["originForeignKey"] ) except Exception, e: print e.message
(Curtis Price formatted code, see Posting Code blocks in the new GeoNet)
I tried this too:
edit = arcpy.da.Editor(env.workspace) edit.startEditing(False, True) edit.startOperation() with arcpy.da.Editor(env.workspace) as fieldEdit: WriteToReport("Calculating " + rc["originPrimaryKey"] + " field values ...") arcpy.CalculateField_management(rc["originTable"], rc["originPrimaryKey"], "!" + rc["realPrimaryKey"] + "!", "PYTHON") WriteToReport("Calculating " + rc["originForeignKey"] + " field values ...") edit.CalculateField_management(rc["destinationTable"], rc["originForeignKey"], "!" + rc["realForeignKey"] + "!", "PYTHON")
I also have the same problem when trying to execute an update cursor on a network dataset feature...
Have you tried to open the editing session like this:
"with arcpy.da.Editor(workspace) as edit:
I did.... I ended up just versioning the data although you shouldn't have t.
This didnt work either:
edit.startEditing(False, False)
