Ownership based access - web
1901
10-06-2015 09:41 AM
Lars_HalvorAnundskaas
New Contributor III
I'm considering ownership based access.
What will appear in the created_by field; the arcgis server user or the database user used when publishing the mxd?
Then what about custom gptools, where I authenticate with a token issued to a specific arcgis server user.
In the gp-tool i use a .sde file to connect to the feature class. I would expect that the database user in the .sde file will appear as creator here, even though some how I would want it to be the arcgis server user.
What I would want to is that all features would be tagged by the user originating from the token.
Any thoughts / comments are welcome
Lars
VikramS
Whats your Auhtentication Mode & Authentication Tier set as ? If the security uses Users and Roles from the AD Group and if the mode/Tier is set to Web then created by field in the feature class will be populated with username. Two prequisites is required for this
  • Enable Editor Tracking in Geodatabase and
  • In Feature Service enable the option Enable ownership based access control on feature
For GP Tool I believe it should populate User id rather than ArcGIS Server Service Account
New Contributor III
Hi, the authentication mode is arcgis server authentication (built in arcgis server users) / GIS server tier.
