add a tile layer from our own server rest service and geoprocessing service
2819
8
10-05-2015 08:50 AM
abukhan
New Contributor III
I need to see an example for adding a tile layer from our own server (cached rest service) using beta4
Also need to see an example to run a geoprocessing service and return a geometry using beta4
all examples for 2D only
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Abu,
Here is an example of using the ArcGISTileLayer:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>ArcGISTiledLayer</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.0beta1/esri/css/esri.css">
  <script src="https://js.arcgis.com/4.0beta1/"></script>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
  </style>
  <script>
    var map;
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/ArcGISTiledLayer",
        "dojo/domReady!"
      function(
        Map, MapView,
        ArcGISTiledLayer
        var tiled = new ArcGISTiledLayer({
          url: "http://tiles.arcgis.com/tiles/dlFJXQQtlWFB4qUk/arcgis/rest/services/Philadelphia2014/MapServer"
        map = new Map({
          layers: [tiled]
        var view = new MapView({
          container: "viewDiv",
          map: map
        map.add(tiled);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
abukhan
New Contributor III
Hi
I appreciate.
Did you have chance to look for the geoprocessor service request call that will return a geometry ?
Thanks.
Abu Khan
Senior Computer Applications Analyst
Division of Information Technology
202-974-7036
KristianEkenes
Geoprocessor is not supported in the 4.0 beta 1 API.
abukhan
New Contributor III
HI:
Any idea about what time geoprocessing will be included (beta2 or release and approx. dates).. We are working on a project that needs geoprocessing…
Another issue, can earlier api (3.4) can be used in addition to api 4 (can both be used same time in the same page) to get some functionalities from both api…?
Thanks.
Abu Khan
202-974-7036
KristianEkenes
The plan is to include Geoprocessor in beta2, which will be released sometime this fall. The specific date of this release has not been determined yet.
Regarding the second question - multiple versions of the API cannot be used in the same app. You'll run into all sorts of issues loading modules. I'm not sure if this is what you're looking for, but you could certainly create two separate apps and load them into the same web page using iframes.
JssrRR
Occasional Contributor II
Jake,
I tried adding tiled layer using your example here, I am not getting any errors but the tile layer is not showing up and even the base map toggle is gone,
Could you please take a look at the JSFiddle and let me know, what is wrong here.
http://jsfiddle.net/JSSR/6811p3um/
Thank you.
KristianEkenes
Saloni RR
The problem is you declare two Map instances with the same name. Remove the second one and your app will work with the added layer. Here's the revised fiddle: Working with JavaScript API Beta 4.1 - JSFiddle
JssrRR
Thanks for looking at it, Yes I see what was wrong there.
