Web AppBuilder and Portal for ArcGIS - Cannot see map layers
2599
10-02-2015 09:39 AM
AdamVellutini
New Contributor III
Greetings,
I have successfully installed Portal for ArcGIS 10.3.1 on an internal server (behind firewall) and have created a map for testing purposes.  I can connect to the Portal from my workstation with Web AppBuilder Development Edition.  I can create an application.  When I go to choose the map from my Portal I can select it just fine, and the thumbnail shows the layers I expect to see.  However, when the map is loaded into my application I cannot see any layers, in the map or LayerList widget.  So I'm really close, but I have this final hurdle to clear.  Has anyone experienced this?
To summarize; I cannot see map services in my Portal map from my workstation WAB.
Thanks for any help you might provide!!
Adam
JayantaPoddar
MVP Esteemed Contributor
Try sharing the Map services with Portal or everyone.
Think Location
AdamVellutini
New Contributor III
Thank you for the suggestion Jayanta.  I have shared the map with everyone and still get the same results.  However I just noticed something new.  I cannot see the map services in Edit mode from Web AppBuilder, but I CAN see them when I launch the application to view it in a new window.  So that seems very strange to me.  It still allows me to work with the application, I just can't see the layers in Edit mode.
Adam
