Selection of all points in polygon - aggregate points
2760
09-30-2015 12:03 PM
KarstenRank
Occasional Contributor III
hi there,
is it possible to select all points in a polygon by the selection of a polygon? Can the summary widget then count the selected points in operations dashboard? It should work like the function Aggregate Points in AGOL Analysis without creating a new layer.
Thanks for your help,
AprilChipman
Replying to this in hopes that this function has become available since 2015...
Anyone know how to make something like this analysis work in Ops Dashboard?
DerekLaw
Esri Esteemed Contributor
Hi April,
FYI, the new web browser-based Operations Dashboard for ArcGIS can do this. You can enable interactivity in the map element, where an end user could select a polygon in an operational layer and it could select features in another layer. This could also filters in other elements like the serial chart.
Actions—Operations Dashboard for ArcGIS | ArcGIS
Hope this helps,
