UpdateCursor setValue() equivalent for da.UpdateCursor?
5508
5
09-30-2015 09:10 AM
KDeVogelaere
Can I rewrite the Python code below using da.UpdateCursor ?  I could not find an equivalent setValue() method for da.UpdateCursor to make the changes.
i = 0
fields= ['LastName','FirstName']
values= ['Jensen','Parky']
rows = arcpy.UpdateCursor(table, where)
for row in rows:
while (i < len(fields)):
       row.setValue(fields, values)
       i += 1
rows.updateRow(row)
del rows, row
Are there any arcpy methods to return the index of tableName.fieldName that we can plug into row[index] when using da.UpdateCursor?
Katie
FreddieGibson
Occasional Contributor III
import arcpy
i = 0
fields = ["LastName", "FirstName"]
values = ["Jensen", "Parky"]
# Option A
with arcpy.da.UpdateCursor(table, fields, where) as cursor:
    for row in cursor:
            row = values
            i+=1
        i=0
        cursor.updateRow(row)
# Option B
    for row in cursor:
        for i,value in enumerate(values):
            row = value
FreddieGibson
import arcpy
i = 0
# Option A
    for row in cursor:
            row = values
            i+=1
        i=0
# Option B
    for row in cursor:
            row = value
KDeVogelaere
Thanks Freddie, what if fields[0] and fields[1] are not the first and second fields in the attribute table?  Will this still work?
For example,
OBJECTID
FirstNameLastName
1JaneDoe
row = value // i = 0  // row[0] is OBJECTID  // fields[0] is FirstName
WesMiller
Regular Contributor III
fields[0] and fields[1] correspond to fields = ["LastName", "FirstName"]
UpdateCursor—Help | ArcGIS for Desktop
DarrenWiens2
MVP Honored Contributor
You decide which fields to include in the cursor. In doing so, you also decide the order of the fields in the cursor. Alternatively, you can include all fields by using '*', which will return all fields in the order found in the attribute table.
Consider a feature class with many fields, in any order, but you are interested in only "name", "age", and "address".
with arcpy.da.UpdateCursor("myFeatureClass",["name","age","address"]) as cursor: # you set cursor field order here
  for row in cursor: # loop through each row in the cursor
    print row[0] # name
    print row[1] # age
    print row[2] # address
vs.
with arcpy.da.UpdateCursor("myFeatureClass",["name","address","age"]) as cursor: # you set cursor field order here
   print row[0] # name
   print row[1] # address
   print row[2] # age
KDeVogelaere
Thanks Darren, this makes perfect sense.
One challenge I was having was updating a 'lastUpdated' column to the localtime() without passing the 'lastUpdated' field to da.UpdateCursor first.  I decided to append the value of localtime() to the end of the values array and 'lastUpdated' to the end of the fields array. It's working beautifully!
