Two questions regarding enhanced search: TabTheme and OpenAtStart
2467
10-01-2015 02:53 AM
MiriEshel
New Contributor III
Hi Robert,
We enjoy very much your enhanced search widget in WAB so thank you very much for sharing it.
We use when we want to open the app with parameters in the URL so that it will be open focused and zoomed to a specific feature.
I have two questions regarding this widget:
1. The OpenAtStart = true does not work with TabTheme but only with FolderTheme. Will it be available also with TabTheme?
2. Is there an option to use URL parameters and immediately after it is called, to close the Search Window?
Thanks a lot,
Miri
RobertScheitlin__GISP
Miri
1.  Open at start works fine in the Tab Theme if you have the widget as one of the first four widgets in the sidebar controller.
2.  Refer to the help doc and the URL search parameters Web AppBuilder for ArcGIS | Help - Enhanced Search widget and you will find a close option.
Miri
MiriEshel
New Contributor III
Hi Robert,
Thank you. I will check it.
miri
Miri,
   Don't forget to mark this question as answered!
