AnsweredAssumed Answered
General - Single Field locator not zooming
Question asked by boyle.matt on Sep 29, 2015
Latest reply on Sep 29, 2015 by boyle.matt
I have a composite locator service made up of 8 individual locators.  Four of the eight locators use the 'General - Single Field' locator style.
If I search for a parcel number using the composite locator service, the service finds the correct value, but zooms to somewhere not anywhere close to the feature.  I need to go back to the default extent and then zoom in on the parcel.  The parcel locator uses the 'General - Single Field' locator style.  I have tried both a polygon and point feature class, with the same result, so I believe the issue is with the locator style.  Am I missing a setting that needs to be done within the Composite Locator for 'General - Single Field' locators?
I've put together a test app, which can be used for seeing the behavior.
Below are sample values you can use within the search widget. All should return a possible value that use the 'General - Single Field' locator style:
Parcel numbers: 102525100100000, 102817600100000
Village: Alice, Covington
Municipality / Township: Putnam Twp
Subdivisions: STONEY POINT HEIGHTS 10TH
All locators are style release 10.3.
ArcGIS Server is 10.3
ArcGIS Desktop is 10.3
Any ideas or suggestions would be appreciated!
Outcomes
