Rotate The map
6999
13
09-23-2015 02:35 PM
RickeyFight
MVP Regular Contributor
Has anyone created a widget or has any example code to rotate the view of the map?
I am wanting to rotate north so it is not up.
Maybe something like this:
Easy navigate the viewpoint and camera in 3D map | ArcGIS API for JavaScript
The problem is that this is for 3D
JeremieCornet1
Occasional Contributor II
this is not possible now.
You have to wait the esri JS api 4.0 (in beta for now) and it's implementation in WebApp Builder.
(NB : the example in your link uses the 4.0 beta API)
JeremieCornet1
CPoynter
Occasional Contributor III
Two years since the last posting to this issue. Is the JS API 4.0 implemented in WebApp Builder yet?
RobertScheitlin__GISP
Yes WAB has the ability to have a 3D map since WAB 2.1.
Welcome—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
CPoynter
Interested in a Rotate widget for 2D maps though as a standard feature in WebApp Builder in ArcGIS Online. Will such a widget be available for those not using WebApp Builder Developer Edition?
The version on AGOL is 2.3 and WAB Dev is also 2.3
CPoynter
Ah, so have a while to wait then. Looking forward to it's implementation. Thank you.
JackZHANG
Will this likely be available after UC in july?
StaleyB
I'd like to know the answer to this as well Jack. Anyone have any further insight since June 14?
JamesBurton3
It's been a year. Any idea when a rotate/compass widget will be available for web app builder??
