RemoveLayer - arcpy
5880
09-24-2015 01:43 AM
Yaron_YosefCohen
Occasional Contributor II
Hello everyone,
i try to remove a layer that located in D:\PROJECTS\zfonGivatShmuel\gis\layers\6_9_15\gvul.shp
with this code but i get an error:
import arcpy,os,sys
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
counter = 0
for mxdname in arcpy.ListFiles("*.mxd"):
    print mxdname # print list of mxd's in the folder
    mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
    df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
    for lyr in arcpy.mapping.ListLayers(mxd, "", df):
        if lyr.dataSource == r"D:\PROJECTS\zfonGivatShmuel\gis\layers\6_9_15\gvul.shp":
            arcpy.mapping.RemoveLayer(df, lyr)
            print 'remove'
    mxd.save()
del mxd
this is the error:
environment.mxd
remove
  File "C:\yaron\shonot\software\gis\tools\YARON_SCRIPTS\RemoveLayer by data source.py", line 15, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\_base.py", line 78, in _get
    (attr_name, self.__class__.__name__))
NameError: The attribute 'dataSource' is not supported on this instance of Layer.
thanks for any help!!
LukeWebb
Occasional Contributor III
Your crash is because one of the "Layers" returned from ListLayers() does not support the data source property! As seen in the error messagge :
A basic reason for this could be because you have "Group" layers setup in your table of contents... these are classed as layers and returned by the ListLayers() function, these obviously have no "DataSource" property, so would cause the crash you see.
Im not sure of the 'proper way' to catch this, but I think this should work (Not tested sorry!):
try:
        print 'remove'
except:
    arcpy.AddMessage("Layer skipped as does not support dataSource property, layer name: " + lyr.name)
Or the full revised script:
import arcpy,os,sys
counter = 0
        try:
                print 'remove'
        except:
    mxd.save()
del mxd
LukeWebb
try:
        print 'remove'
except:
import arcpy,os,sys
counter = 0
        try:
                print 'remove'
        except:
    mxd.save()
del mxd
FreddieGibson
As an alternative to the try/catch approach you could just check if the layer supports datasource.
import arcpy
import os
import sys
from arcpy import mapping as m
arcpy.env.workspace = r"C:\Project"
counter = 0
for mxdPath in arcpy.ListFiles("*.mxd"):
    print(mxdPath)
    mxd = m.MapDocument(mxdPath)
    df  = m.ListDataFrames(mxd, "Layers")[0]
    for lyr in m.ListLayers(mxd, "", df):
        if not lyr.supports("DATASOURCE"):
            continue
            m.RemoveLayer(df, lyr)
            print("Remove")
    mxd.save()
    del mxd
