Is it possible to make the infowindow/pop up window draggable
4634
8
09-22-2015 09:34 AM
AzizaParveen2
New Contributor III
Dear Geonet Users,
We have several GIS apps built using JavaScript API where our users want to drag  infowindow / pop up window to their desired location on map. Is it possible to that with JavaScript API? I will appreciate your thoughts and ideas on this.
YueWu1
by Esri Regular Contributor
Hi Aziza,
Please check this sample that shows how to make the infoWindow draggable.
This is can be done with the dojo/dnd/Moveable module.
dojo/dnd/Moveable simply takes a DOM Node reference. To make the InfoWindow of the map draggable, pass map.infoWindow.domNode to the Moveable constructor.
MichaelVolz
Esteemed Contributor
This would be very useful.
YueWu1
Hi Aziza,
AzizaParveen2
New Contributor III
Thanks so much Yue for your reply. I could not get into the sample link.
I will try the dojo/dnd/Moveable module.
YueWu1
Try it again it should work now
AzizaParveen2
New Contributor III
Nice exactly what I wanted, can't wait to try , Thank you so much Yue
AzizaParveen2
New Contributor III
Finally, I was able to try your example, worked like a charm, Thanks a ton for help:)
JeffJacobson
Occasional Contributor III
I made a few minor improvements / modifications to your sample.
  • Updated to ArcGIS API v3.14.
  • Replaced some dojo-specific methods (query and css class manipulation) with browser built-in equivalents.
  • Removed reference to "dojo/on" module. Replaced with Moveable.on().
  • Modified CSS to remove use of !important.
  • Removed duplicate variable declaration.
body, html {
    width: 100%;
    height: 100%;
    margin: 0;
    padding: 0;
#map {
    height: 100%;
    width: 100%;
    margin: 0px;
.esriPopupWrapper .title {
    cursor: move;
.esriPopup .pointer.hidden {
    display: none;
require([
    'esri/arcgis/utils',
    'dojo/dnd/Moveable'
], function (
    arcgisUtils,
    Moveable
    var webMapItemID = "fe0827dfea2441f5b206b0e2c37b79cd";
    arcgisUtils.createMap(webMapItemID, "map", {}).then(function(response) {
        var map = response.map;
        var handle = map.infoWindow.domNode.querySelector(".title"); //query(".title", map.infoWindow.domNode)[0];
        var dnd = new Moveable(map.infoWindow.domNode, {
            handle: handle
        // when the infoWindow is moved, hide the arrow:
        dnd.on('FirstMove', function() {
            // hide pointer and outerpointer (used depending on where the pointer is shown)
            var arrowNode =  map.infoWindow.domNode.querySelector(".outerPointer");
            arrowNode.classList.add("hidden");
            arrowNode =  map.infoWindow.domNode.querySelector(".pointer");
        }.bind(this));
AzizaParveen2
New Contributor III
Thanks so much Jeff.
