Extracting cells using a categorical raster with raster calculator
2882
09-20-2015 10:23 AM
SusanneWagner
I have some problems for a raster query. Can somebody help me please?
I have 2 raster files: parcels with different id (1-7) and landuse also with different ids 1-4).
I want to use the raster calculator for query to create an own raster layer with parcel == 2 and including all kind of landuse (1-4) which exists on those parcels....
But I don't know how to form that query. I tried it with pick and con but without success.....
Thanks in advance!!!
Tags (1)
curtvprice
MVP Esteemed Contributor
If you don't apply a false expression, you get NoData, so this will work:
Con("Parcels" == 2, "Landuse")
DanPatterson_Retired
Use the Combine tool which will produce all the unique combinations which is more useful that doing one query at a time.
http://desktop.arcgis.com/en/desktop/latest/tools/spatial-analyst-toolbox/combine.htm
GabrielUpchurch1
Occasional Contributor III
In addition to Dan's suggestion (which should do what you need), this map algebra expression applied in Raster Calculator should yield all of the land use cells that overlap with Parcel 2 cells:
Con("Parcels" == 2,"Landuse",SetNull("Parcels","Landuse"))
Alternatively, instead of setting all of the parcel cells not equal to 2 to NoData, you could simply set them to 0.  It just depends on your needs.  Here is that syntax:
Con("Parcels" == 2,"Landuse",0)
curtvprice
SusanneWagner
Thank you for all help!!!
