Bing Map showing blank
4688
11
09-19-2015 07:44 AM
JulieBiju
Hi All,
Urgent ...Pls help me.
Bing map is not loading in my application .It is showing blank screen.
Rest all maps working fine.Pls Help.Bing map key I used is correct
java script used below
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Map.aspx.vb" Inherits="Default2" %>
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
    <head runat="server">
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
        <meta http-equiv="X-UA-Compatible" content="IE=7" />
        <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
        <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
        <title>Google Maps Layer in ArcGIS JS API</title>
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css"/>
    <style type="text/css">
        html, body, #mapDiv{
        padding: 0;
        margin: 0;
        height: 100%;
            z-index: -1;
        .auto-style3 {
            height: 20px;
        .auto-style6 {
            height: 2%;
            width: 279px;
        .auto-style7 {
            width: 279px;
        #TxtAltareeqEng {
            width: 55px;
        #TxtAltareeqEng0 {
            width: 55px;
    </style>
     <script type="text/javascript">
         var djConfig = {
             parseOnLoad: true,
             baseUrl: './',
             modulePaths: {
                 // if use local copy, make sure the path reference is relative to 'baseUrl', e.g.:
                 //'agsjs': '../build/agsjs'
                 // use absolute path for online version. Note sometimes googlecode.com can be slow.
                 'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.05/build/agsjs'
        </script>
        <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4">
        </script>
         <script type="text/javascript" src="Scripts/gmapslayer_compiled.js">
        </script>
        <script src="Scripts/jquery-2.1.1.js" type="text/javascript"></script>
            window.onerror = function (msg, url, linenumber) {
                alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
                return true;
            dojo.require("esri.map");
            dojo.require("dijit.form.Button");
            dojo.require("dijit.layout.BorderContainer");
            dojo.require("dijit.layout.ContentPane");
            //dojo.require("agsjs.layers.GoogleMapsLayer");
            dojo.require("esri.layers.graphics");
            dojo.require("esri.virtualearth.VETiledLayer");
            var map;
            var streetMap, esriTopo, gMap, BingLayer;
            var graphicsLayer;
            var Map1, Map2;
            var lastposdate  = "";
            var DoorOpenClose = 'NO';
            function init() {
                var initExtent = new esri.geometry.Extent({
                    "xmin": -14628212,
                    "ymin": 714227,
                    "xmax": 7718305,
                    "ymax": 9832858,
                    "spatialReference": {
                        "wkid": 102100
                //alert('init');
                map = new esri.Map("mapDiv", {
                    extent: initExtent,
                    logo: true
                Map1 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
                Map2 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServ...";
                streetMap = new esri.layers.ArcGISDynamicMapServiceLayer(Map1, {
                map.addLayer(streetMap);
                esriTopo = initLayer(Map2, "esriTopo");
                BingLayer = new esri.virtualearth.VETiledLayer({
                    bingMapsKey: "A......",
                    mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
                map.addLayer(BingLayer);
                gMap = new gmaps.GoogleMapsLayer({
                    visible: false,
                map.addLayer(gMap);
                graphicsLayer = new esri.layers.GraphicsLayer();
                map.addLayer(graphicsLayer);
                var resizeTimer;
                dojo.connect(map, 'onLoad', function (theMap) {
                    dojo.connect(dijit.byId('map'), 'resize', function ()
                    { //resize the map if the div is resized
                        clearTimeout(resizeTimer);
                        resizeTimer = setTimeout(function () {
                            map.resize();
                            map.reposition();
                        }, 500);
            function initLayer(url, id) {
                var layer = new esri.layers.ArcGISDynamicMapServiceLayer(url, {
                    visible: false
                map.addLayer(layer);
              return layer;
            function changeMap(layers) {
                hideImageTiledLayers(layers);
                for (var i = 0; i < layers.length; i++) {
                    layers.show();
                    alert(layers.id);
            function hideImageTiledLayers(layers) {
                  for (var j = 0, jl = map.layerIds.length; j < jl; j++) {
                    var layer = map.getLayer(map.layerIds);
                    if (dojo.indexOf(layers, layer) == -1) {
                        layer.hide();
                dojo.addOnLoad(init)
        </script>
</head>
<body class="claro"  >
<form id="form1" runat="server">
    <div style="width: 100%; height: 100%">
                <table id="Tablecontrols0"   style="font-size: 15px; z-index: 101;
            background-color: #5B748B; width: 100%; height: 100%;">
            <tr style="font-family: Times New Roman">
                <td style="border-style: none; background-color: #496277; "
                    valign="top" class="auto-style6" >
                     </td>
                <td align="left"   style="border-style: none; background-color: #496277; height: 2%;"
                    valign="top" class="auto-style3" >
                     </td>
            </tr>
                <td style="border-style: none;"
                    valign="top" bgcolor="#496277"   >
                     </td>
                <td style="border-style: none; background-color: white; height: 500px;"
                    valign="top" id="td11" >
            <div id="mapDiv" runat ="server"  dojotype="dijit.layout.ContentPane" region="center"
                style="border:1px solid #000; visibility: visible; height: 100%; ">
                <br />
                <br />
            </div>
            <div id="buttons" style="position:absolute; right:75px; top:83px; z-Index:999;">
                <button dojoType="dijit.form.Button"   onClick="changeMap([streetMap]);">
                    Al Tareeq(EN)</button>
                <button dojoType="dijit.form.Button" onClick="changeMap([esriTopo]);">
                    Al Tareeq(AR)
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('roadmap')">
                    Google Street
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('satellite')">
                    Google Statellite
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('hybrid')">
                    Google Hybrid
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('terrain')">
                    Google Terrain
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);BingLayer.setMapStyle('esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL');">
                    Bing Aerial
                </button>
                    Bing Aerial with labels
                </button>
                  <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);">
                   Roads
                </button>
            </div>   </td>
            </tr>
            </table>
     </div>
        </form>
</body>
</html>
ChrisSmith7
I would recommend upgrading to 3.14 and fixing all of your breaking changes when implementing ArcGIS API for JavaScript Sandbox
I say this because 2.x was retired June of 2014; it is no longer supported by Esri.
http://downloads.esri.com/support/product%20life%20cycle/online_gis/ArcGISWebMappingAPIs_PLC.pdf
JulieBiju
Pls help meee....................
TimWitt2
Julie it is hard to test without an actual bingmap key.
JulieBiju
Dear Tim,
This is the one i am using for testing
TimWitt2
Hey Julie,
did you try to use this approach before? ArcGIS API for JavaScript Sandbox
Tim
JulieBiju
Tim,
If I will change this 2.4 to 3.14, Then many script errors will get. I tried once and I should use the ESRI map as base layer otherwise googlemap will not work.
ChrisSmith7
JulieBiju
Chris,
Will do as suggested.
In this case any sample available for using googlemap also?
ChrisSmith7
Yeap! Someone created an app:
http://www.arcgis.com/home/item.html?id=a8f78cc6adea48cb8e962d7e36b9d010
UPDATE:
It looks like the last version supported is early 3.x per the forum postings... I don't think it will work for you in 3.14. The original author hasn't provided any updates since 2012.
JulieBiju
Yes. Exactly. I tried this also but not working fine.3.0" is old. I have to erase google map from my solution I think.
