Will call to StopEditOperation with StartEditing(bool withUndoRedo = false) commit the change to a database
2917
09-17-2015 06:49 PM
MarkMindlin
Occasional Contributor III
Hi there,
It is for 10.3 Desktop version and Informix database with versioning.
The task is to validate some feature attribute which was updated by user. I should do it before SaveEdits (StopEditing(true/false)) with SQL in Informix data base.
I need to clarify if the actual update is commited to database after StopEditOperation() was called from C# code.
If yes, what table (feature class) is updated?
I use multiversion view and cannot see it.
What is the table with postfix "_mv"?
Any help would be appreciated.
MarkMindlin
The Informix database driver is set to Default (There are also options like "Show uncommited" and others)
FreddieGibson
When editing data in an enterprise geodatabase you should start the edit session using the StartMultiUserEditing method of the IMultiuserWorkspaceEdit interface. As a result of the data being versioned it will automatically implement the undo and redo stacks. While editing the data I believe the changes will be stored in the A&D tables. The information will be committed to the versioned view after stopping the edit operation. More information about this process can be seen on the following page:
Editing with the geodatabase API
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/#/Editing_with_the_geodatabase_API...
