AnsweredAssumed Answered
Problem with Projection
Question asked by igor92128 on Sep 18, 2015
Latest reply on Sep 18, 2015 by Dan_Patterson
I have a Query Layer that I have added to ArcMap from SQL and the spatial reference ID is 4326. After adding the view into ArcMap and ensuring that the data frame has the same spatial reference, the data is still not lining up correctly. I have even exported it as a shape file, deleted the PRJ file and imported it back and added the coordinate system 4326 but the result is still the same. When I drop it into ArcMap, it displays properly but the extent is:
Top: 2170108.000000 dd
Right: 6609886.000000 dd
Bottom: 1748025.000000 dd
Left: 6151029.000000 dd
and it should match the extent of my other data:
Top: 33.382430 dd
Right: -116.292880 dd
Bottom: 32.564070 dd
Left: -117.350790 dd
If I try to manually set the extent to match the above, the data disappears.
Any ideas?
Igor
Outcomes
