Python toolbox - compiling two processes
4366
12
09-15-2015 01:36 AM
KarolinaKorzeniowska
I am trying to build a Python Toolbox, like in the attached example.  I would like to implement an evaluation of mean like in Focal Statistics​ and subtraction like in Raster Calculator. In the documentation page is an example how to implement Focal Statistics, but this example is for Script Tool Wizard, not for Python Toolbox. Is there some example how to implement it and combine with raster calculator in Python Toolbox?
Below is attached my code. For now I implemented Focal Statistics, but it does not work.
Thanks in advance.
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "My"
        self.alias = "model"
        # List of tool classes associated with this toolbox
        self.tools = [MyModel]
class MyModel(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "MyModel"
        self.description = ""
        self.canRunInBackground = True
    def getParameterInfo(self):
       # Workspace parameter
       param0 = arcpy.Parameter(
            displayName="Input Workspace",
            name="in_workspace",
            datatype="DEWorkspace",
            parameterType="Required",
            direction="Input")
       # Set the filter to accept only local (personal or file) geodatabases
       param0.filter.list = ["Local Database"]
       # First parameter
       param1 = arcpy.Parameter(
            displayName="Input Raster Dataset",
            name="in_rasterdataset",
            datatype=["DERasterDataset","DERasterCatalog"],
            direction="Input")
       in_features.filter.list = ["Raster"]
       # Second parameter
       param2 = arcpy.Parameter(
            displayName="Units",
            name="units",
            datatype="Double",
            parameterType="Optional",
            direction="Input",
            enabled=False)
       # Third parameter
       param3 = arcpy.Parameter(
            displayName="Output Raster Dataset",
            name="out_rasterdataset",
            parameterType="Derived",
            direction="Output")
       out_features.filter.list = ["Raster"]
       param2.parameterDependencies = [param1.name]
       param2.schema.clone = True
       params = [param0, param1, param2, param3]
       return params
  def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
  def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
  def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
  def execute(self, parameters, messages):
        # Import system modules
  import arcgisscripting
  # Create the Geoprocessor object
  gp = arcgisscripting.create()
  try:
       # Set local variables
       InRaster = "in_rasterdataset"
       OutRaster = "out_rasterdataset"
       InNeighborhood = "NbrRectangle,3,3,Map"
       InNoDataOption = "DATA"
       # Check out the ArcGIS Spatial Analyst extension license
       gp.CheckOutExtension("Spatial")
       # Execute FocalStatistics
       gp.FocalStatistics_sa(InRaster, InNeighborhood,"", InNoDataOption)
  except:
       # If an error occured while running a tool, then print the messages.
       print gp.GetMessages()
        return
MahtabAlam1
Right click your tool that has red X and click the only option from the context menu "Why..." This will give you the details of the error.
DanPatterson_Retired
So what is the question?  Are you getting errors? Sifting through the code isn't easy since it isn't formatted, use the syntax highlighting option in the advanced editor.
I changed the code in my previous post. I have a syntax error which I cannot find, I have an info that the error is in the 20th line of the code, but I do not see anything wrong in this line. Also I do not know how to implement second step (subtraction) without saving on disc the result from the first step.
WesMiller
Regular Contributor III
Looks like indentation errors on lines 22 and 82 what is the error message you are getting
I have syntax error, because my Python Toolbox is crosses by red X. I corrected the indentation of lines - this was a copy-paste error, in my original code it was fine.
WesMiller
I'm not sure what the red X means did you move the script from its location and the tool box can no longer find it?
MahtabAlam1
Thank you. I did not know about this option. I have found two mistakes which I corrected. But I still have two more errors, which I do not know how to remove. The errors are:
  File "<string>", line 41, in getParameterInfo
  File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\arcobjects\_base.py", line 94, in _set
    (attr_name, self.__class__.__name__))
NameError: The attribute 'list' is not supported on this instance of Filter.
In line 94 I tried to change:
for
InNeighborhood = NbrRectangle(3, 3, "CELL"),
but it still does not work, so I do not know what is wrong. Any suggestions?
import arcpy
    def __init__(self):
        .pyt file)."""
        self.label = "My"
    def __init__(self):
            direction="Input")
       # First parameter
            direction="Input")
       param1.filter.list = ["Raster"]
       # Second parameter
            name="units",
            datatype="Double",
            direction="Input",
            enabled=False)
       # Third parameter
            direction="Output")
       param3.filter.list = ["Raster"]
       param3.parameterDependencies = [param1.name]
       param3.schema.clone = True
       return params
        return True
        return
        return
    try:
    except:
       return
Luke_Pinner
MVP Regular Contributor
Karolina Korzeniowska:
You haven't specified the type of filter: Defining parameters in a Python toolbox—Help | ArcGIS for Desktop
Thank you for the answer. I added a line with data type. Now I do not have any syntax error, but the script still does not work, so I do not know what can still be wrong.
# First parameter
       direction="Input")
  param1.filter.type = "ValueList"
  param1.filter.list = ['Raster']
