I'm trying to understand how to use the FieldMappings object in arcpy, but am getting confused.
I have two tables, an input table and a target table. I'm trying to use the Append tool to load data from the input table into the target table. I have two fields within each table that need to be mapped.
Input
NEAR_FID
BUFF_DIST
Target
WellOID
Distance
Mapping should be:
NEAR_FID = WellOID
BUFF_DIST = Distance
Any suggestions on how to map these fields using the FieldMappings object would be greatly appreciated!
Here is how I'm using field mappings for my street index creator hope this helps
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-classes/fieldmappings.htm
# Create a new fieldmappings and add the two input feature classes. fieldmappings = arcpy.FieldMappings() fieldmappings.addTable(DissolvedStreets) fieldmappings.addTable(InputGrid) jField = fieldmappings.findFieldMapIndex(gridField) fieldmap = fieldmappings.getFieldMap(jField) fieldmap.mergeRule = "join" fieldmap.joinDelimiter = "," fld_length = fieldmap.outputField fld_length.length = 255 fieldmap.outputField = fld_length arcpy.AddMessage(str(fieldmap.outputField.length)) fieldmappings.replaceFieldMap(jField, fieldmap) # Process: Spatial Join arcpy.SpatialJoin_analysis(DissolvedStreets, InputGrid, outfc, "#", "#", fieldmappings)
Following might help a bit:
# define new mappings and load default from fc or table fieldmappings = arcpy.FieldMappings() fieldmappings.addTable(yourFCorTable) # now you define the ouput fields fieldmap1 = fieldmappings.getFieldMap(1) outField1 = fieldmap.outputField outField1.name = "WellOID" outField1.aliasName = "WellOID" fieldmap1.outputField = outField1 fieldmap2 = fieldmappings.getFieldMap(2) outField2 = fieldmap2.outputField outField2.name = "Distance" outField2.aliasName = "Distance" fieldmap2.outputField = outField2 # now you can use your field mappings
