Changing base (tile) map
5194
09-12-2015 05:09 PM
joepublic
New Contributor III
I have a esri-leaftlet app that works when I use a cloudfront base (tile) map but I get errors when I change to a Stamen base map.
(See link below)
ICGC WEB PORTAL   ....
When I click on a button to see the first (News) button, I get the following error:
Uncaught TypeError: Cannot read property 'trim' of undefined
o.Util.trim @ leaflet.js:5
cleanUrl @ Util.js:387
exports.Task.L.Class.extend.initialize @ Task.js:28
o.Class.extend.e @ leaflet.js:5
query @ Query.js:229
(anonymous function) @ icgcWebMap5.html:261
n.event.dispatch @ jquery.js:4435
n.event.add.r.handle @ jquery.js:4121
And if I click on any of the other buttons, I get the following error:
Uncaught TypeError: Cannot read property 'query' of undefined
(anonymous function) @ icgcWebMap5.html:329
I at a total loss as to why this is happening.  Any help would much appreciated
Chris
joepublic
New Contributor III
Hey John,
My bad!! I was using an old version of my app
Chris
JohnGravois
please reread my response to your previous geonet post, as you encountering the exact same problem.
Updating an esri-leaftlet app
you are still passing the url of the service you'd like to query as a plain string to L.esri.Query(), rather than within the options object which is currently required.
var query = L.esri.query(tableURL).where("type like '" + buttonType.value + "'");
// at line 257 needs to be
var query = L.esri.query( { url: tableURL } ).where("type like '" + buttonType.value + "'");
joepublic
New Contributor III
Hey John,
Chris
