“Diagram properties” for models created in ArcGIS Pro,
4659
24
09-13-2015 01:02 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to set the “Diagram properties” for models created in ArcGIS Pro,
Thank you
Best
Jamal
Jamal Numan
Robert_LeClair
Esri Notable Contributor
Ah - okay - yes, you can do that with AGP 2.3.  In my before picture is a model with the default view of left to right.  In the ModelBuilder-Diagram contextual tab upper right of the ribbon (blue), I click on the Flip Orientation in the Orientation Group.  The result is my second picture.  Top to bottom!
LeftToRight
Top2Bottom
JamalNUMAN
For example, how to choose the “orientation” to be “top to bottom” for models created in ArcGIS Pro?
Jamal Numan
DanPatterson_Retired
I would have to look further in those links that I sent you.
JamalNUMAN
I need to check if the “diagram properties” is implemented in 2.0.1
Jamal Numan
don't see anything that specific Jamal, but I rarely use it... just what is in this link...
http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/diagram-and-display-proper...
curtvprice‌ uses ModelBuilder way more than I, so perhaps he has toyed with the Pro offerings in 2.0 or 2.1
JamalNUMAN
For me, I would love to have this option as I prefer to have “top to bottom” model instead of “left to right”. Not sure why we should lose features\capacity as we move from version to another.
Jamal Numan
curtvprice
MVP Esteemed Contributor
I've never used this feature in ArcMap. It sure doesn't look available in Pro to me:
Diagram and Display Properties—ArcGIS Pro | ArcGIS Desktop
JamalNUMAN
I think that the only way out for this is that the developers of ArcGIS Pro need to have deep look on all options\settings\features that are already available in ArcGIS and try not to miss any of them.
Jamal Numan
Jamal... you should close your threads even if the answers aren't to your liking.  You can either choose an answer (like it or not), mark as assumed answered or convert to a discussion)
