Print widget
3716
10
09-11-2015 10:03 AM
JoeCollin
installed the print widget the only problem I am having with the print is that when it prints it is cutting off the sides of the map
ChristopherOlsen
Occasional Contributor III
Have you contacted the author?
JoeCollin
no not yet but the author is ESRI
ChristopherOlsen
can you provide the link?
MichaelVolz
Esteemed Contributor
Is this the out-of-the-box print widget that ESRI provides with the OD?
ChristopherOlsen
For the record, there is no out-of-the-box Print widget that Esri provides.  The list of supported out-of-the-box widgets are here:
Types of widgets in operation views—Operations Dashboard for ArcGIS | ArcGIS
JoeCollin
I did an add-in and the author says ESRI
ChristopherOlsen
please post the link or any information on this.
If it's "esri_id", the author is someone at Esri Indonesia and is not affiliated with the corporate dev team.
JoeCollin
Yes that is the add-in I used, there was only a couple that showed up,  would you know of some other widget or add-in that can be used,  explains why the export map add-in does not work either
ChristopherOlsen
I thought that was the case...  It looks like the last update on this one was in March and we have had 2 releases since then, so chances are the widget isn't compatible anymore.
I don't know of any Print widgets available right now, but this might be a good sample for us to look at doing.  We are encouraging all users to migrate to using the new JavaScript extensions for Ops Dashboard instead of WPF. These new extensions have the ability to run in desktop and web dashboards, so you only have to write the code once to use both ways.
