Google Play Services 7.5.0 and geotrigger-sdk:1.2.0 conflict error
4817
09-10-2015 07:53 PM
MikelButron
My build.grade has the following lines:
compile 'com.google.android.gms:play-services-base:7.5.0'
compile 'com.google.android.gms:play-services-gcm:7.5.0'
compile 'com.google.android.gms:play-services-location:7.5.0'
However when I add the geotrigger sdk dependency
           compile    'com.esri.android.geotrigger:geotrigger-sdk:1.2.0'
I get the following error:
Error:Execution failed for task ':processDebugResources'.
> Error: more than one library with package name 'com.google.android.gms'
  You can temporarily disable this error with android.enforceUniquePackageName=false
  However, this is temporary and will be enforced in 1.0
Any ideas how to solve it?
Regards,
DanO_Neill
Occasional Contributor III
The GeoTrigger SDK has a dependency on Google Play Services (6.5.87) so you need to import the same level as the GeoTrigger SDK or remove the dependencies in your project entirely.
