Is it possible to create a stacked textSymbol? If so, what is the syntax for the linebreak?
in python it is "\n" in some environments it is "\r\n" might be worth a try since I found one example in this environment
I tried \n already, but that didn't work. I also tried \r\n, but nothing. It just prints them as characters. I also tried <br>.
How about trying the ASCII character code for line break, carriage return, etc?
var text = 'This is line one' + String.fromCharCode(10) + 'This is line two';
That didn't work, but this looks like a possibility. I haven't tried it yet. suytt/esri.symbol.MultiLineTextSymbol · GitHub
Update: I couldn't get this to work for me either. Maybe it's too out of date, although it did say it was 2014, which isn't that old.
Tracy, I able to get this to work. You can save the js file - esri.symbol.MultiLineTextSymbol.js and then just add this:
<script type="text/javascript" src="js/esri.symbol.MultiLineTextSymbol.js"></script>
Hope this help.
Thanks.
I usually just add two symbols and adjust the yoffset value. I'm guessing the same approach was wrapped up nicely in the referenced github lib.
