address-to-locations-complete runs callback function repeatedly
2278
09-09-2015 10:54 AM
AzizaParveen2
New Contributor III
Hi, I am using address-to-locations-complete event with our custom locator, now if I type wrong address or garbage address, and click find button, the locator task runs just fine and brought 0 result and then show an alert msg saying "Address not Found", first time it works fine but I input wrong address or garbage address again, the alert box comes up twice, and this goes on and on..which is very annoying, did any of you see this behavior? I will appreciate any help in this regard, thanks--AZIZA
I made a very simple bare bone app with only few lines of code in it, I am pretty sure you guys can replicate this issue.
var searchByAddress, showResultLocation;
require([
         "esri/tasks/locator",
         "dojo/domReady!"
], function (locator) {
    esriConfig.defaults.io.alwaysUseProxy = false;
    esriConfig.defaults.io.corsDetection = false;
    esriConfig.defaults.io.corsEnabledServers.push("http://services.arcgisonline.com/");
    esriConfig.defaults.io.corsEnabledServers.push("http://www.arcgis.com/");
    var rvcLocator = new locator(locator);
    searchByAddress = function () {
        var address = {
            SingleLine: document.getElementById("search").value
        var options = {
            address: address,
            outFields: ["*"]
        showResultLocation = function (evt) {
            var resultLocations = evt.addresses.length;
            if (resultLocations == 0) {
                alert("No Address found");
                return;
        rvcLocator.on("address-to-locations-complete", showResultLocation);
        rvcLocator.addressToLocations(options);
HTML
<!DOCTYPE html>
<html>
<head>
   <title>ArcGIS API for JavaScript | Basic Search</title>
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
   <style>
      html,
      body,
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script src="http://js.arcgis.com/3.14/"></script>
   <script src="JS/test.js"></script>
</head>
<body>
   <input id ="search" type="text"/>
   <input id="searchAddBtn" type="button" value="FIND" onclick="searchByAddress();"/>
</body>
</html>
RobertScheitlin__GISP
Aziza,
   The reason is because you are adding the "address-to-locations-complete" function each time you run the search. So each time you search you are adding it again and thus the multiple alerts.
Aziza,
AzizaParveen2
New Contributor III
Thank you so much Robert, it worked
