Custom polygon with user specified dimensions
3651
5
09-09-2015 02:46 AM
by Anonymous User
Not applicable
how to create a custom rectangle with specified width and lenght to use in model builder? any suggestions?
DanPatterson_Retired
If you just need the extent of the polygon and not the actually polygon itself, then you can set the analysis extent to the desired shape.  If you actually need a rectangle, you can create a featureclass/shapefile with a python script.  What approach do you need?
by Anonymous User
Not applicable
I need to create a rectangle over an exsisting polygon. This rectangle must be 4 times bigger than existing polygon.
You can do the math and create a featureclass in the normal way specifying the points that produce the proportional area you need.  There a number of point combinations that one could create and the will be affected by the desired width and/or height you choose.  You will be constrained in both directions by the diameter of the circle, but you can scale the height and width to a accommodate your desired area
by Anonymous User
Not applicable
Solved
you might want to post your solution
