AnsweredAssumed Answered
IIdentifyDialog shows up old identify window
Question asked by kroy_74 on Sep 9, 2015
Dear friends
       i have developed ArcMap desktop tool  which overrides existing (using sample code)Arcmap identify tool where  some layers excluded for displaying information.The code works fine without any error but the issue is  old identify window shows up which does not have  sorting and other options in the window.Kindly help me for this issue.
Public Sub DoIdentify(ByVal x As System.Int32, ByVal y As System.Int32)
        Dim pMxdoc As IMxDocument
        Dim activeView As IActiveView
        Dim trackCancel As ITrackCancel = New CancelTrackerClass()
        pMxdoc = m_application.Document
        activeView = pMxdoc.ActiveView
        If activeView Is Nothing Then
            Return
        End If
        Dim map As IMap = activeView.FocusMap
        Dim identifyDialog As IIdentifyDialog = New IdentifyDialog
        identifyDialog.Map = map
        'Clear the dialog on each mouse click
        identifyDialog.ClearLayers()
        Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
        Dim display As ESRI.ArcGIS.Display.IDisplay = screenDisplay ' Implicit Cast
        identifyDialog.Display = display
        Dim identifyDialogProps As IIdentifyDialogProps = CType(identifyDialog, IIdentifyDialogProps) ' Explicit Cast
        Dim enumLayer As ESRI.ArcGIS.Carto.IEnumLayer = identifyDialogProps.Layers
        enumLayer.Reset()
        Dim layer As ESRI.ArcGIS.Carto.ILayer = enumLayer.Next
        Do While Not (layer Is Nothing)
            If CheckLayerCantainsInLayerList(layer) = False Then
                identifyDialog.AddLayerIdentifyPoint(layer, x, y)
            End If
            layer = enumLayer.Next()
        Loop
       identifyDialog.Show()
    End Sub
Outcomes
