jeff.pace
javascript 3.14 issue with Google Street View
Discussion created by jeff.pace on Sep 9, 2015
Latest reply on Sep 9, 2015 by jeff.pace
Just wanted to make people aware of an issue with the 3.14 api and Street View
The 3.14 api introduces a new css element in esri.css
.map .container .layersDiv > div {
    pointer-events: none;
This breaks google street view if you have it embedded in your map div as a child, as it uses pointer-elements
As a workaround, when street view is visible, loop through the elements and turn pointer-events on
array.forEach(query('.map .container .layersDiv > div'), function(node){
   domStyle.set(node, 'pointerEvents', 'auto');
and then when you close street view, turn them back off
   domStyle.set(node, 'pointerEvents', 'none');
Outcomes
