I have a code like below which is suppose to add over 600 points into a GraphicLayer `projectsG` and eventually add the `projectsG` to `layer1` and `map` but I am not sure what I am doing wrong in
projectsG = new esri.Graphic(project, symbol).setInfoTemplate(projectInfoTemplate); } console.log(thepoints); layer1 = new esri.layers.GraphicsLayer(); for (i = 0; i < points.length; ++i) { layer1.add(projectsG); }
part which only adds the Last project into the map! Can you please take a look at following code and let me know what I am doing wrong in looping?
var layer1, var thepoints=[]; var projectInfoTemplate; var projectsG; var points = [ { "ProjectID":"15260", "Longitude":"-118.641508", "Latitude":"51.949915", }, { "ProjectID":"17043", "Longitude":"-125.444557", "Latitude":"51.097552", }, .... { "ProjectID":"13009", "Longitude":"-130.257086", "Latitude":"56.882834", }, { "ProjectID":"17088", "Longitude":"-124.160699", "Latitude":"50.897618", } ]; function drawSeries1() { for (var i = 0; i < points.length; i++) { var projects = points; var project = new esri.geometry.Point(projects.Longitude, projects.Latitude); project = esri.geometry.geographicToWebMercator(project); var symbol = new esri.symbol.PictureMarkerSymbol("e-Chartreuse.png", 32, 32); projectInfoTemplate = new InfoTemplate(); projectInfoTemplate.setTitle("Project Details"); projectInfoTemplate.setContent('<div>Some Att Here</div> '); projectsG = new esri.Graphic(project, symbol).setInfoTemplate(projectInfoTemplate); thepoints.push(projectsG); } console.log(thepoints); layer1 = new esri.layers.GraphicsLayer(); for (i = 0; i < points.length; ++i) { layer1.add(projectsG); } map.addLayer(layer1); }
Solved! Go to Solution.
Behrouz,
This code is legacy style so you should really consider moving the code to AMD style. Otherwise you are looping through your points twice and you are doing geographicToWebMercator when a Point geometry can be created using the lat lon. Several things in your code could be optimized.
Here is the code in AMD:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Points</title> <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } </style> <script src="http://js.arcgis.com/3.14/"></script> <script> var map; require([ "esri/map", "esri/geometry/Point", "esri/layers/GraphicsLayer", "esri/symbols/PictureMarkerSymbol", "esri/graphic", "dojo/_base/array", "esri/InfoTemplate", "dojo/domReady!" ], function( Map, Point, GraphicsLayer, PictureMarkerSymbol, Graphic, arrayUtils, InfoTemplate ) { map = new Map("map",{ basemap: "topo", center: [ -120, 54 ], zoom: 6, minZoom: 2 }); map.on("load", mapLoaded); function mapLoaded(){ var layer1, mp, att; var points = [ { "ProjectID":"15260", "Longitude":"-118.641508", "Latitude":"51.949915", }, { "ProjectID":"17043", "Longitude":"-125.444557", "Latitude":"51.097552", }, { "ProjectID":"13009", "Longitude":"-130.257086", "Latitude":"56.882834", }, { "ProjectID":"17088", "Longitude":"-124.160699", "Latitude":"50.897618", } ]; var symbol = new PictureMarkerSymbol("images/e-Chartreuse.png", 32, 32); layer1 = new GraphicsLayer(); var infoTemplate = new InfoTemplate("Project Details","${*}"); arrayUtils.forEach(points, function(project){ att = { "Project Id": project.ProjectID, "Longitude": project.Longitude, "Latitude": project.Latitude }; mp = new Point(project.Longitude, project.Latitude); var projGra = new Graphic(mp, symbol, att); layer1.add(projGra); }); layer1.setInfoTemplate(infoTemplate); map.addLayer(layer1); } }); </script> </head> <body class="claro"> <div id="map"></div> </body> </html>
Behrouz,
Thanks Robert but can you please let me know what the AMD is?
Behrouz,
Here is a blog and another link that will help. The abc’s of AMD | ArcGIS Blog
