Ok so I am guessing this is just a restriction of the use but if you set up a signature image and make it required Survey123 does not recognize if a signature is done so you cant send your survey. Is this just a limitation or am I doing something wrong?
Solved! Go to Solution.
Not your mistake: This is just our oversight. Please add an enhancement request in the repo. If a signature question is flagged as 'required' we should not let you submit when the signature is completely clear.
Thanks a lot. Good catch.
Its a holiday weekend! No working. Will do, actually your point is correct too but I mean even if you have a signature in the box and its required then it will not allow you to submit.
Posted in github as I dont seem to have access to the link you gave.
Thanks! Sorry, I provided wrong link.
