AnsweredAssumed Answered
Why won't my repaired data links stay repaired?
Question asked by penjie23 on Sep 2, 2015
Latest reply on Sep 2, 2015 by penjie23
I have data attached to a .lyr file. When I pull the layer into the map the map they appear as broken links. I can fix this no problem, using properties, set data source and navigating to the file, after which the layers work fine. However if I then remove the layer and re-add it the link is once again broken. Should this be happening and would it work to repair the data links of each feature and then regroup these into the .lyr's?
Outcomes
