attribute edit
3721
14
08-31-2015 03:08 AM
SatyanarayanaNarmala
New Contributor III
Hi all,
I am trying to implement attribute edit using attribute inspector, the service is displaying but pop up info not getting displayed.
If the problem is with the proxy setting, can anybody help with it. i am using IIS server.
here is the code
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Editable FeatureLayer in Selection Only Mode with Attribute Inspector</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
      .esriAttributeInspector {height:100px;}
      .esriAttributeInspector .atiLayerName {display:none;}
      .esriAttributeInspector .atiButton{
        margin-top:1px;
        margin-right:45px;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/AttributeInspector",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/config",
        "esri/tasks/query",
        "dojo/query",
        "dojo/parser",
        "dojo/dom-construct",
        "dijit/form/Button",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, AttributeInspector,
        SimpleLineSymbol, SimpleFillSymbol, Color,
        ArcGISDynamicMapServiceLayer, esriConfig,
        Query,dojoQuery,
        parser, domConstruct, Button
        parser.parse();
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
   // esriConfig.defaults.io.proxyUrl = "/proxy/";
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [78.20, 19.00],
          zoom: 11
        map.on("layers-add-result", initSelectToolbar);
        var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/IRR/srsp_canal_WRK1/MapServer");
        petroFieldsMSL.setDisableClientCaching(true);
        map.addLayer(petroFieldsMSL);
        var petroFieldsFL = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/IRR/srsp_canal_WRK1/FeatureServer/1", {
          mode: FeatureLayer.MODE_SELECTION,
          outFields: ["objectid","code", "codename", "length", "description", "status_work", "la_status", "ip_status"]
        var selectionSymbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
            new SimpleLineSymbol(
                "solid",
                new Color("yellow"),
            null
        petroFieldsFL.setSelectionSymbol(selectionSymbol);
        petroFieldsFL.on("edits-complete", function() {
          petroFieldsMSL.refresh();
        map.addLayers([petroFieldsFL]);
        function initSelectToolbar(evt) {
          var petroFieldsFL = evt.layers[1].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
            selectQuery.geometry = evt.mapPoint;
            petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
              if (features.length > 0) {
                //store the current feature
                updateFeature = features[0];
                map.infoWindow.setTitle(features[0].getLayer().name);
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
              else {
                map.infoWindow.hide();
          map.infoWindow.on("hide", function() {
            petroFieldsFL.clearSelection();
          var layerInfos = [
              'featureLayer': petroFieldsFL,
              'showAttachments': false,
              'isEditable': true,
              'fieldInfos': [
                {'fieldName': 'objectid', 'isEditable': false, 'objectid': 'objectid:'},
                {'fieldName': 'code', 'isEditable': false, 'CANAL CODE': 'Acreage:'},
                {'fieldName': 'codename', 'isEditable': false, 'label': 'CANAL NAME:'},
                {'fieldName': 'length', 'isEditable': false, 'label': 'LENGTH IN METERS:'},
                {'fieldName': 'description', 'isEditable': false, 'label': 'CANAL DESCRIPTION:'},
                {'fieldName': 'status_work', 'isEditable': true, 'tooltip': 'WORK PROGRESS', 'label': 'WORK PROGRESS STATUS:'},
                {'fieldName': 'la_status', 'isEditable': true, 'tooltip': 'LAND AQUISITION', 'label': 'LAND AQUISITION STATUS:'},
                {'fieldName': 'ip_status', 'isEditable': true, 'tooltip': 'IP CREATED', 'label': 'IP CREATED STATUS:'}
          var attInspector = new AttributeInspector({
            layerInfos: layerInfos
          }, domConstruct.create("div"));
          //add a save button next to the delete button
          var saveButton = new Button({ label: "Save", "class": "saveButton"},domConstruct.create("div"));
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
          saveButton.on("click", function() {
            updateFeature.getLayer().applyEdits(null, [updateFeature], null);
          attInspector.on("attribute-change", function(evt) {
            //store the updates to apply when the save button is clicked
            updateFeature.attributes[evt.fieldName] = evt.fieldValue;
          attInspector.on("next", function(evt) {
            updateFeature = evt.feature;
            console.log("Next " + updateFeature.attributes.objectid);
          attInspector.on("delete", function(evt) {
            evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
          map.infoWindow.setContent(attInspector.domNode);
          map.infoWindow.resize(350, 240);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
      <div id="detailPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        Click a field to display the attribute inspector with customized fields.
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" id="mapDiv"></div>
    </div>
  </body>
</html>
HerdisGudbrandsdottir
New Contributor III
I've just added the circle buffer to your code - then when you click a point, the inspector opens:
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
        margin-top:1px;
        margin-right:45px;
    </style>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "dojo/query",
        "dojo/parser",
"esri/graphic",
  "esri/geometry/Circle",
      ], function(
        Query,dojoQuery,
        parser, domConstruct, Button, Graphic, Circle
        parser.parse();
          basemap: "streets",
          zoom: 11
                "solid",
            null
  var circleSymb = new SimpleFillSymbol(
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
          ), new Color([255, 255, 0, 0.25])
        var circle;
          //var petroFieldsFL = evt.layers[1].layer;
   circle = new Circle({
            center: evt.mapPoint,
            geodesic: true,
            radius: 0.2,
            radiusUnit: "esriMiles"
          map.graphics.clear();
          var graphic = new Graphic(circle, circleSymb);
          map.graphics.add(graphic);
           selectQuery.geometry =circle.getExtent();;
  //selectQuery.geometry = evt.mapPoint;
              else {
          var layerInfos = [
              'isEditable': true,
              'fieldInfos': [
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
New Contributor III
Hi Narmala,
Try fiddling with the geometry in the query - the mapPoint is very distinct, so to return features from a mapPoint you would have to be very precis [read lucky] to hit a feature. If you create a buffer around your point, you will get much better results:
Select with Feature Layer | ArcGIS API for JavaScript
require ([
"esri/graphic",
        var circle;
            geodesic: true,
            radius: 0.2,
           selectQuery.geometry = circle.getExtent();
New Contributor III
Hi Herdis,
I am wondering how you get the info display.
I am not good in programming. can You help me in solving this.
Regards,
Satyanarayana
New Contributor III
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
        margin-top:1px;
        margin-right:45px;
    </style>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "dojo/query",
        "dojo/parser",
"esri/graphic",
      ], function(
        Query,dojoQuery,
        parser.parse();
          basemap: "streets",
          zoom: 11
                "solid",
            null
        var circle;
            geodesic: true,
            radius: 0.2,
              else {
          var layerInfos = [
              'isEditable': true,
              'fieldInfos': [
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
New Contributor III
Hi Herdis,
Thank you Very Much,
Regards,
Satyanarayana
bharathreddy
hello herdis,
I am unable to get attribute inspector
its showing a error esri.layers.FeatureLayer: unable to find 'objectid' field in the layer 'fields' information [url: http://localhost:6080/arcgis/rest/services/editing/FeatureServer/1]
regards,
bharath
New Contributor III
Hi Bharath,
I would make sure that the layer objectIdField of the featureLayer is in fact 'objectid'.
I can't see your url, it is on localhost. What happens if you use the layer that you posted earlier ("http://gisserver.cgg.gov.in/arcgis/rest/services/IRR/srsp_canal_WRK1/FeatureServer/1)? Here the objectIdField is 'objectid'. so that works on my side (I can edit it and save changes).
Kind regards Herdis
bharathreddy
I took that layer from arcgis service directory
New Contributor III
OK. How about the layer that fails now, with missing objectid. Do you have a field called 'objectid' in that one?
bharathreddy
Yes i have ms herdis
