Oracle 12.1.0.2 and SDE 10.2.2
2492
08-31-2015 07:10 AM
SherrieKubis
In Oracle 12c we allow the nightly system stats gathering to collect statistics for us.
We have one feature class that causes a timeout.  In reproducing this manually, I find that it's the domain index, with this SQL running.
This FC is dropped and recreated nightly, so the possibility of gathering and then lock stats isn't there.   Also, I have yet to get it to finish.
I tried to put a degree on the index, but running the stats doesn't pick that up.
BEGIN
   SYS.DBMS_STATS.GATHER_TABLE_STATS (
      OwnName           => 'SDECREATOR'
     ,TabName           => 'SITES_EDIT_WCPFLG1'
     ,Estimate_Percent  => dbms_stats.auto_sample_size
     ,Method_Opt        => 'FOR ALL COLUMNS SIZE AUTO '
     ,Degree            => dbms_stats.default_degree
     ,Cascade           => FALSE
     ,No_Invalidate  => FALSE);
END;
BEGIN
   SYS.DBMS_STATS.GATHER_INDEX_STATS (
     ,IndName           => 'A1245_IX1'
     ,Estimate_Percent  => NULL
END;
SELECT /*+ no_parallel(b) no_parallel_index(b) dbms_stats cursor_sharing_exact use_weak_name_resl dynamic_sampling(0) no_monitoring */
        DBMS_ROWID.rowid_block_number (b.ROWID)
    FROM (SELECT s.sp_id,
                 s.gx,
                 s.gy,
                 ROW_NUMBER () OVER (PARTITION BY s.sp_id ORDER BY s.gx, s.gy) rncol
            FROM SDECREATOR.S1375_IDX$ s) sp,
         SDECREATOR.SITES_EDIT_WCPFLG1 b
   WHERE rncol = 1 AND b.ROWID = sp.sp_id
ORDER BY sp.gx, sp.gy, sp.sp_id;
