I have a story map journal project that I completed last year. When I built it, the "share" link used a bit.ly URL and everything worked fine. Recently I checked it and the links now use arcg.is as the shortcut and the links don't work. If I simply switch arcg.is to bit.ly and leave the rest of the URL alone, it works. Is there something I was supposed to do in my configuration when ESRI made this change?
Here is the story map: http://www.nreca.coop/solar
Sorry about your issue.
I have been able to fix it, and the arcg.is link generated by the application is now working.
The bit.ly link continue to works too.
You should not have experienced that issue, we haven't heard other stories impacted by that issue so I hope this was a little glitch on bit.ly side.
