AnsweredAssumed Answered
Range Dome Analysis: ArcGIS for the Military
Question asked by gaboyarleque on Aug 26, 2015
Latest reply on Sep 15, 2015 by gaboyarleque
Has anyone of you used the range dome analysis template? I am trying to understand and use this template. I followed the instructions given in the solutions website about setting up the template. However when I run the analysis I keep getting the ERROR 050005 (See below).
I checked the modelbuilder to look for any broken connections, re-run the model again and got the same error. So then I editted  the model and kept the section that was causing the error, which is one of the first steps in the model (see below). I run that small process and got the same error message.
So if any of you have worked with this template and have been able to use it, I would appreciate your insights on this issue.
thanks a lot,
Gabriel
Outcomes
