ArcGlobe Draw Distance / Viewpoint for extruded features
2875
08-25-2015 11:55 PM
StephenHayes
Hi
I'm new to arcGlobe (using 10)  and cant seem to work out if its possible to change the draw distance for extruded polygon features.
Presently if I zoom out from a extruded layer the features will disappear in an order dependant on their size (the smaller ones first), is there anyway to alter this draw distance, I've searched the options but cant seem to find anything that makes a difference? Ideally I would like to keep the smaller ones on a larger scale.
Tags (3)
NathanShephard
Hi Stephen,
The 10.0 release of ArcGlobe had an auto-culling behavior that - for display-performance reasons - doesn't show smaller 3D objects (multipatches and extruded polygons) as the viewing distance increases. We changed that behavior in 10.2.1 such that the layer's distance-visibility setting is honored explicitly.
So, the fix for your issue is to upgrade to a newer release (10.2.1 or higher).
Hope this helps!
Thanks, Nathan.
Esri
NathanShephard
Hi Stephen,
Hope this helps!
Thanks, Nathan.
Esri
