I have a script here and seems simple enough but for some reason after the script is done it creates an empty feature class. I don't get any errors.. Am i missing something?
# Import arcpy module import arcpy import os from arcpy import env from datetime import datetime as d startTime = d.now() arcpy.env.workspace = "C:\GIS\weeds\Weeds.gdb" arcpy.env.overwriteOutput = "True" arcpy.env.qualifiedFieldNames = False CITY = "C:\GIS\weeds\Weeds.gdb\City_Limits" Taxparcels = "C:\GIS\weeds\Weeds.gdb\Parcels" ADMIN = "C:\GIS\weeds\Weeds.gdb\ADMIN" temp = "C:\GIS\weeds\Weeds.gdb" # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(Taxparcels, "In_memory\Par") # Process: Analysis Erase arcpy.Erase_analysis("In_memory\Par", CITY, "In_memory\Par_ERASE","") arcpy.MakeFeatureLayer_management("In_memory\Par_ERASE", "In_memory\Par1") # Process: Add Join try: arcpy.AddJoin_management("In_memory\Par1", "ACCOUNT", ADMIN, "Acct", "KEEP_ALL") except BaseException as e: pass #arcpy.FeatureClassToFeatureClass_conversion("In_memory\Par1", temp, "TaxWeed1")#working arcpy.MakeFeatureLayer_management("In_memory\Par1", "In_memory\Par2") # Process: Select Layer By Attribute arcpy.SelectLayerByAttribute_management("In_memory\Par2", "NEW_SELECTION", "\"TEXT\" = 'common area'") # Process: Delete Features if int(arcpy.GetCount_management("In_memory\Par2").getOutput(0)) > 0: arcpy.DeleteFeatures_management("In_memory\Par2") # Process: Make Feature Layer (2) TaxPar2 = "weedtax" arcpy.MakeFeatureLayer_management("In_memory\Par2", TaxPar2) arcpy.FeatureClassToFeatureClass_conversion(TaxPar2, temp, "TaxWeed") arcpy.Delete_management("In_memory\Par") arcpy.Delete_management("In_memory\Par1") arcpy.Delete_management("In_memory\Par2") arcpy.Delete_management("In_memory\Par_ERASE") #arcpy.Delete_management("In_memory\ParCel") try: print '(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')' except Exception, e: # If an error occurred, print line number and error message import traceback, sys tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
Solved! Go to Solution.
My guess, line #39 is deleting all of the features, so line #46 is copying an empty feature class to make a new, empty feature class. When using the Select Layer By Attribute tool, be careful because all records are returned if no records meet the criteria.
ok, so if no records are found in line 35, then at 39 it's selecting all records because nothing was found. So how can i by pass line 35 in case nothing is found?
Although a bit kludgy, you can run a Get Count before the selection and store that number. Then, after the selection, you can compare the new Get Count with the old one. If they are the same, nothing was selected.
