Enable Feature Access in Query Layer SDO_Geometry
4277
08-21-2015 02:10 PM
AlexanderMena
I have a query layer that I need publish as a feature service with capabilities (Feature Access, create, update delete) on ArcGIS for Server.
When I publish the services only with capabilities of Mapping, the service work fine. When I activate capabilities of Feature Access I get a error 00134
on the service editor (Analyse).
I followed the recommendation's blog "http://blogs.esri.com/esri/supportcenter/2014/04/08/the-evolution-of-query-layers/"
This is a example of my SQL Query Layer.
select IDE_EVENTO, IDE_ELEMENTO, NOM_GENERACION, NOM_AREA, NUM_CLIENTES_ESPECIALES, NUM_OTROS_CLIENTES, NUM_KVA_NOSUMINISTRADOS,
VLR_COSTOENERGIANOSUMINISTRADA, GEO_COORDENADA, IDE_ESTADO_TRAFOS, CLASSID, REVISIONNUMBER
from DMSEPM.DMST_GIS_EVENTO
--Only one table
--No clause Where
Note: I added a column auto increment ObjectID without result.
Environment:
ArcGIS for Desktop 10.3.1,  ArcGIS for Server 10.3, Data Base is Oracle 11g with SDO_Geometry.
  What I need for publish the Query Layer as a feature service for Edit Rest API.
Thank you for your Help
AlexanderMena
Well, several thing that we could consider:
1. The workflows are intended for databases that do not have the geodatabase system repository tables populated.
My DB has a system repository tables populated. Solution: I changed it to SDO_Geometry only.
2. The table has unique constraint over one column different to ObjectID. Solution: I deleted all constraint, except those relation with ObjectID.
With the changes above, was possible publish and make editing over the feature services without a problem.
Best Regard.
