Is there any way to stop Geoprocessing adding the results to the current map (like 10.x)?
3217
08-21-2015 03:28 AM
AdamDavis
Adam
DrewFlater
You cannot set this option specifically for geoprocessing. However you can set a mapping option so that newly added layers are not visible (turned off in the Contents pane). This applied to geoprocessing as well.
Make newly added layers visible setting
AdamDavis
Found it myself (at least in code).
await Geoprocessing.ExecuteToolAsync("management.CopyFeatures", parameters,
        null, new CancelableProgressorSource(progDlg).Progressor, GPExecuteToolFlags.None)
Set GPExecuteFlags to None.
Adam
DrewFlater
AdamDavis
Hi Drew,
Thanks for that. It would be great if a future ArcGIS Pro included the same setting for not adding to the current map as ArcGIS.
Adam
