Story Tour Failure
3659
12
08-20-2015 09:57 AM
Yavapai-ApacheNation
My first Story tour was a great success.  When I tried to edit it, it failed.  Since then I have remade it three times.  Each time it fails.  Screen Shot 2015-08-20 at 9.52.15 AM.png
All my points and images are gone.  It loads an empty map.
GregoryL_Azou
Occasional Contributor III
Sorry about your issue but thanks for taking the time, that last Map Tour gave me a lead. The web map associated with the Tour is http://www.arcgis.com/home/webmap/viewer.html?webmap=a7d55448cfea47379cfbe93a2b287552
If you try to open the attribute table, you will get an error that let me think that when you created your tour you must have copy/pasted some text that ArcGIS Online don't like.
This can happen when you are copy/pasting content from the web or rich text editor like Word into the builder. One thing you could do is to copy/paste the text into a simple editor like notepad before copy/pasting into builder. By doing that you may or not notice some weird character in your text. Remove those if you see them.
Hope this helps
GregoryL_Azou
Sorry about that.
Can you share a link to your tour so I can take a look?
I guess you used the option to upload your pictures to ArcGIS Online and added them one by one. In that case a Feature Service is created and you should be able to see it in My Content. Can you find it?
http://arcg.is/1J5Q1Nx the share link.
I just discovered my build for it is still here… it just won't open to view. I have saved it.
https://yan-tribe.maps.arcgis.com/apps/MapTour/?appid=66931cf696ea485a88d7301e82d14080&edit
My content is pretty cluttered. It seems like each time I tried a new tour a new feature was required. At the time I didn't realize that was going to be a feature layer.
Yes, this last time I did add my images from my computer, but the time before from Flicker. I never understood why it happened differently.
Still confused….
Judie Piner
Preservation & Technology
Yavapai-Apache Nation
GregoryL_Azou
Does the application open using the following link https://yan-tribe.maps.arcgis.com/apps/MapTour/?appid=66931cf696ea485a88d7301e82d14080&edit ?/external-link.jspa?url=https://yan-tribe.maps.arcgis.com/apps/MapTour/?appid=66931cf696ea485a88d730...
If you can open the application, you would need to share it publicly so I can diagnose it, you can do that using those buttons
If you can't, something have gone really wrong. I suggest you try one more time. Reload the application every once in a while after you save so hopefully you can see what goes wrong.
I don’t think it will open. Its been spinning for awhile.
Judie Piner
Still spinning… not going to load. It also tried to load in the same tab I originally had it, so I lost my build of it.
Judie Piner
GregoryL_Azou
Something must be really wrong. If it doesn't load after couple of seconds, it's not going to load.
We have a tool that should help you diagnose what can have gone wrong, if you can sign-in at My Stories | Story Maps , and click on the story that has errors and let me know how it looks.
It doesn’t say there are any issues. iF I open from there it is like a new project… empty of content. I’ll do it over again and hope I don’t make the same mistake, whatever it is.
Thanks for all your help.
Judie Piner
GregoryL_Azou
You are welcome, sorry about that. Make sure to track your action and reload the application often, it looks like the layer was deleted from the map and this should not happen without any manual action.
Hi again,
Made two more trys.
For the first I tried editing the existing map. I added four pictures and points. Saved, closed, and reopened it. Nothing there.
Then I began a brand-new one (tour3; Tour of Exodus History; http://arcg.is/1NsSiZz). Again I added three pictures, saved, and reopened. Still nothing. You can see a generic map, but there is no layer.
Judie Piner
