I am able to place multiple coordinates in Map but i am not able to display seperate info for the individual coordinates.
Here i am attaching my piece of code which displays same info for all the coordinates.
Can you please fix it.
Note: Replace BINGSKEY.
Solved! Go to Solution.
Bhaskar,
You will have to add attributes to the graphics you create.
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"> <title>Insert title here</title> <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css"> <title>Create Map and add a dynamic layer</title> <style> html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } </style> <script src="http://js.arcgis.com/3.14/"></script> <script> var map; require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ImageParameters", "esri/symbols/PictureMarkerSymbol", "esri/graphic", "esri/virtualearth/VETiledLayer", "esri/geometry/Polygon", "esri/geometry/Point", "esri/layers/GraphicsLayer", "esri/renderers/SimpleRenderer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/Color", "esri/geometry/webMercatorUtils", "dojo/domReady!" ], function ( Map, ArcGISDynamicMapServiceLayer, ImageParameters, PictureMarkerSymbol, Graphic, VETiledLayer, Polygon, Point, GraphicsLayer, SimpleRenderer, SimpleFillSymbol, SimpleLineSymbol, Color, webMercatorUtils) { map = new Map("mapDiv", { sliderOrientation: "horizontal" }); var baseMapLayer = new VETiledLayer({ bingMapsKey: 'YOUR BING KEY', mapStyle: VETiledLayer.MAP_STYLE_AERIAL_WITH_LABELS, id: 'bingMapLayerId' }); map.addLayer(baseMapLayer); var points = new Array(); var polygon = new Polygon(); var point; point = webMercatorUtils.xyToLngLat(-8303533.953231358, 4917717.3663619868); points[0] = new Point(point[0], point[1]); point = webMercatorUtils.xyToLngLat(-8303533.7143373974, 4917697.7793284087); points[1] = new Point(point[0], point[1]); point = webMercatorUtils.xyToLngLat(-8303602.0299349511, 4917698.4960196903); points[2] = new Point(point[0], point[1]); point = webMercatorUtils.xyToLngLat(-8303602.2688289117, 4917717.6051774034); points[3] = new Point(point[0], point[1]); point = webMercatorUtils.xyToLngLat(-8303533.953231358, 4917717.3663619868); points[4] = new esri.geometry.Point(point[0], point[1]); polygon.addRing(points); //console.log(polygon); var locationLayer = new GraphicsLayer(); map.infoWindow.resize(245, 125); var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]) ); locationLayer.add(new Graphic(polygon, symbol)); var psymbol = new PictureMarkerSymbol({ "angle": 0, "xoffset": 0, "yoffset": 11, "type": "esriPMS", "url": "http://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png", "contentType": "image/png", "width": 28, "height": 28 }); //console.log(symbol); var array = ['driver1', 'driver2']; for (var i in array) { //Add attributes to the graphics if (array == 'driver1') { locationLayer.add(new Graphic(new Point(-74.6162653, 40.3452031), psymbol, {"driver": "Dwell Time -50mins"})); } else { locationLayer.add(new Graphic(new Point(-74.6062653, 40.3452031), psymbol, {"driver": "Dwell2 Time -30mins"})); } } locationLayer.on("mouse-over", function (event) { map.graphics.clear(); //use the maps graphics layer as the highlight layer var graphic = event.graphic; console.info(event.graphic.attributes); //set the map info content based on the graphics attribute map.infoWindow.setContent(event.graphic.attributes.driver); map.infoWindow.setTitle("CBHU Driver"); map.infoWindow.show(event.screenPoint, map.getInfoWindowAnchor(event.screenPoint)); }); //listen for when map.graphics mouse-out event is fired //and then clear the highlight graphic //and hide the info window locationLayer.on("mouse-out", function () { map.graphics.clear(); map.infoWindow.hide(); }); map.addLayer(locationLayer); var renderer = new SimpleRenderer(symbol); //console.log(polygon.getCentroid()); map.centerAndZoom(polygon.getCentroid(), 20); }); </script> </head> <body> <div id="mapDiv"></div> </body> </html>
Bhaskar,
Working fine.
