AnsweredAssumed Answered
ago assistant with portal: cannot see contents
Question asked by nengeesri-ca-esridist Employee on Aug 18, 2015
Latest reply on Nov 30, 2017 by RayCrew
Hi, I am trying to copy contents from one portal to another. The issue is when I log into the source portal (10.3) I cannot see its contents. I tested this with various browsers, from within the domain and from outside the firewall. I even tried to reverse it so that I log into the destination (10.3.1) portal and then try to log into the source portal when I select "I want to copy contents". The strange thing is that I can see the contents of my destination portal but not the source. When I try to search for a known item, it results in 0
Both portals are set to anon access as well as SSL only. Both are accessible outside the firewall. Is there a setting I am missing in the source portal?
Outcomes
