Filter with GIS Online
3002
5
08-17-2015 04:13 AM
JeffChartrand
New Contributor III
Help, I think I am going mad.  In the help menu for ArcGis Online under Show Tables it states that:
"To create a query expression that filters what feature data appears in the map and table, click the arrow to the right of Table Options and click Filter."
I do not seem to have this option can anyone shine a light on this issue?
I can Show Selected records, Clear Selected records, Centre on selected records.  I can select records manually but can not find the filter option anywhere.
Cheers
Jeff Chartrand
TimWitt2
Jeff,
Take a look at my screenshot, maybe that will help!
Tim
JeffChartrand
New Contributor III
Dear Tim,
Thank you for your prompt response.  I do not seem to have those options in my ArcGIS Online.   What I have is as below:
TimWitt2
Jeff,
The filter option may only be available to feature services and not shapefiles?
*edit: I just tested it and the filter option does not work on uploaded shapefiles.
Tim
JeffChartrand
New Contributor III
Thank would make sense but the file I was working on was an imported CSV as per their instructions and was a simple feature type file.  It will not allow me to put csv on as an attachement.  I include a screen grab which shows the data file at the bottom.
Cheers
Jeff
TimWitt2
I think filtering does not work with any data that is stored within the map and not stored in "My Content".
I just added a CVS and I wasn't able to filter either.
If this is an organizational account, I would add the CVS to ArcGIS Desktop and then publish it as a feature service.
