Anyone have any issues with the command ImportMetadata_conversion not working on ArcGIS server?
3308
9
08-13-2015 08:54 AM
MichaelMiller2
Occasional Contributor III
I'm have a script that we run as a scheduled task to build feature classes and we are trying to import metadata from pre-configured xml files. The ImportMetadata_conversion will run when the script is invoked on the desktop but not when invoked from ArcGIS server.  Is this a bug in the 64bit version of arcpy on the server?
MichaelMiller2
Apparently the arcpy Metadata conversion tools will not run on ArcGIS install using 64-bit python. Looks like we'll have to install a 32-bit ArcGIS Desktop on the server.
CCWeedcontrol
would be nice if you can post your current code...
MichaelMiller2
import arcpy
metadata = r"\\itdhq1apt90\InputData\CreateGISDataWarehouse\assets\Bridge_metadata.xml"
output_bridge = r"\\itdhq1apt90\InputData\CreateGISDataWarehouse\output\Staging.gdb\Assets\Bridge"
arcpy.ImportMetadata_conversion(metadata,"FROM_ARCGIS",output_bridge,"ENABLED")
PacoAlverez
New Contributor III
Are you getting any errors?
MichaelMiller2
Errors when run on server
PacoAlverez
New Contributor III
MichaelMiller2
As you can see from the code above, I'm using UNC paths assigned to variables.
CCWeedcontrol
ok,
your using arcpy.ImportMetadata_conversion
try using MetadataImporter_conversion
try something like.
  1. # Local variables...
  2. sde_DEVGIS_Wetlands = "Database Connections\\HOU-SRVRNPRD2 (devgis - sde).sde\\sde.DEVGIS.DevelopmentAndTesting\\sde.DEVGIS.Wetlands"
  3. Wetlands_xml = "K:\\GIS Data\\Metadata\\Wetlands.xml"
  4. arcpy.MetadataImporter_conversion(Wetlands_xml, sde_DEVGIS_Wetlands)
MichaelMiller2
Both ImportMetadata_conversion and MetadataImporter_conversion work when invoked in a test script on the desktop, but neither work when invoked by the same test script on ArcGIS server.
MichaelMiller2
