How do I create halos and limit label scale in ArcGIS Online maps?
2909
08-12-2015 07:26 AM
wcESRI
I want to create labels in ArcGIS online that have the following qualities.
1) The ability to appear at certain scales.
2) The ability to show halos.
I would like to have the halos appear similar as the map at http://tiogacp.maps.arcgis.com/apps/MapJournal/index.html?appid=5625b7aa9d3f426d89864f999f2dc272&web...
I am using ArcGIS Pro.  I can share the web map and I can get the scale functionality to work.  However, if I alter it in ArcGIS online, I lose the scale limits.
Thank you in advance.
JakeSkinner
Esri Esteemed Contributor
Hi Christopher,
If you have ArcGIS Server, you can publish the MXD as a map service.  Your label properties and scale ranges will be maintained.
If you do not have ArcGIS Server, you can create a Tile Package from your MXD.  The tile package can be uploaded to ArcGIS Online, and then published as a Tile Service.
