Web App Builder: Search and Edit
2784
08-09-2015 05:55 PM
NatalieScott1
New Contributor III
So this is following on a little from this question:
Edit Widget maybe broken in new Web Apps?
Which I thought I had solved, but am now having more issues with.
I have a web app that has a single editable layer in it.
1. I open the app, open the editing widget, click on a point - the point is editable
2. If I search for an address, the map will zoom to it but then I can't click on any points to access the Edit window - even after clearing the geocoder search bar. All points come up with the result from the geocode:
I searched for 50 Kilmore and then cleared the Search Bar. All points now return this popup.
3, The workaround I've found is to exit and re-enter the edit widget, at which point the points become editable again.
Does anyone else have this problem or, better yet, a solution?
Jianxia Song​, this might be one for you...
Thanks!
ZhifangWang
Hi Natalie,
Confirmed with our developers, this should be a bug, we'll try to fix this. Current work around is as you say, to reopen the Editor widget, sorry for the inconvenience.
And also thanks for the feedback and letting us know:)
ZhifangWang
Hi Natalie,
Jianxia
Natalie,
As my colleague Zhifang mentioned, this is a bug and will be fixed in the coming release.
Jianxia
NatalieScott1
New Contributor III
Thanks Jianxia Song​ and Zhifang Wang​, I look forward to the update
