Hello guys...!
Is it possible to insert supporting pages such as text information, graphs, and tabular data into map book without using python scripts.
If yes, how?
If not, What can i do because i don't know how to use python and I'm trying to add the supporting pages into my map book.i need your help please..?
Regards!
Kelvin
I do mine in Acrobat.
Can you give me a little bit explanation on how to do that?
Using Acrobat Standard or Pro (i.e., not Reader), you just take all the pdf files and combine them. "Document|Insert Pages".
So the first step is to create all the individual pages you need using whatever software you want, and then combine them. I use Word to make my cover, and I use Illustrator & Photoshop to do various graphics.
Ok thanks it seems to take a lot of process to complete the task.I think python is the only simple solution.
Yeah, I think Python would be easy to implement. See code example here: PDFDocument—Help | ArcGIS for Desktop
Xander... getting an 'Unexpected error' message on the link... is this it?
h t t p : / / desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-mapping/pdfdocument-class.htm
in pure text and having to space out http
it has been flakey... try again, or copy and past the link I posted BUT remove the spaces I embedded
