Feature Details Widget Crashes Operations Dashboard
3164
08-04-2015 07:22 AM
NilsBabel
Occasional Contributor II
I have a operations dashboard application that uses a feature service and three table views (published with a feature service) as external data sources.  When I go to add a new feature details widget if I choose one of the table views as the Data Source Ops Dashboard crashes immediately.  Is this a bug?  Am I doing something wrong?  Is there a workaround?
ChristopherOlsen
Occasional Contributor III
Hi Nils,
I tested this out with a single and multi view dashboard and did not see any crashes.  What version are you using?  Could you share the URL for the service?
Thanks!
Chris
NilsBabel
I'm actually not sure how to tell which version I'm using, but I know I just downloaded the latest windows app. Can you email me (nils.babel@ocio.usda.gov) and I'll send you the URL for the service?
ChristopherOlsen
I think the issue here and why it's failing is due to the table missing an OID field.  Can you try adding that (or trying a service with table with OID present) and see if that resolves it?
NilsBabel
That's problem.  The table is based on a database view so it doesn't have an OID and I can't add one.
