vb.net arcobjects show fields from feature
3698
7
08-03-2015 11:50 AM
SusanneWagner
A big hello,
I try to show the field names (alias names) of a feature class. I found a code snippet but I don't succeed to get it to run
Can somebody tell me please what is wrong in the code? (System: Arcgis 10.2, Visual Studio2012)
Thanks a lot for any help!!
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.Geodatabase
Public Class AnzahlFelderButton
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Public Sub New()
End Sub
Protected Overrides Sub OnClick()
ShowDistinctFieldAliasNames(My.ArcMap.Document)
End Sub
Shared Sub ShowDistinctFieldAliasNames(ByVal featureClass As IFeatureClass)
      Dim fields As IFields = featureClass.Fields
      Dim field As IField = Nothing
      For i As Integer = 0 To fields.FieldCount - 1
      ' Get the field at the given index.
      field = fields.Field(i)
           If field.Name <> field.AliasName Then
                Console.WriteLine("{0} : {1}", field.Name, field.AliasName)
           End If
      MsgBox(field.AliasName)
      My.ArcMap.Application.CurrentTool = Nothing
End Sub
Protected Overrides Sub OnUpdate()
Enabled = My.ArcMap.Application IsNot Nothing
End Sub
Private Sub DisplayDistinctFieldAliasNames()
Throw New NotImplementedException
End Sub
End Class
KenBuja
MVP Esteemed Contributor
I'm glad to help. Please use the "Correct Answer" icon on the appropriate post to signify that this question has been answered (and also mark any posts that has been helpful). This will help others if they are searching for similar queries on this subject.
KenBuja
Your function is expecting a feature class
but you're passing in a document
To pass in a feature class, you'll have to find a layer in that document and verify that it's a feature class. Something like this:
dim pLayer As ESRI.ArcGIS.Carto.ILayer
dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer
pLayer= My.ArcMap.Document.FocusMap.Layer(0)
if TypeOf pLayer Is ESRI.ArcGIS.Carto.IFeatureLayer then
  pFLayer = pLayer
   ShowDistinctFieldAliasNames(pFLayer.FeatureClass)
end if
Although not mentioned in this post, but in the comment on this question on GIS.StackExchange, you mentioned that ArcMap was crashing with a application error. When this happens, use Try..Catch blocks in your code to figure out what's the problem.
  Try
  Catch ex As Exception
    System.Windows.Forms.MessageBox.Show(ex.ToString, "Error", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Error)
  End Try
End Sub
SusanneWagner
Dear Ken,
thank you a lot for you help and that you also answered me in the other discussion! You see I have big difficulties to understand this subject
You explained it great that I have to verify an active layer as feature class and I modified the code. For me its now a bit lighter in darkness but there is still a bigger mistake inside my code. Unluckily also the try and catch command doesn't show me anything. May I ask you again if you could have a look to the code what could be wrong?
Thank you a lot in advance!!
Public Sub New()
End Sub
      Try
           System.Windows.Forms.MessageBox.Show(ex.ToString, Windows.Forms.MessageBoxButtons.OK,        Windows.Forms.MessageBoxIcon.Error)
      End Try
End Sub
Dim pLayer As ESRI.ArcGIS.Carto.ILayer
Dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer
pLayer = My.ArcMap.Document.FocusMap.Layer(0)
If TypeOf pLayer Is ESRI.ArcGIS.Carto.IFeatureLayer Then
      pFLayer = pLayer
End If
' Get the Fields collection from the feature class.
' On a zero-based index, iterate through the fields in the collection.
      End If
End Sub
End Sub
End Sub
End Class
KenBuja
I apologize for not being clear enough in my response. The code I showed for the Try..Catch was using your original code. Here's what you should have for the OnClick function.
    Try
            pFLayer = pLayer
        End If
        System.Windows.Forms.MessageBox.Show(ex.ToString,"Error", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Error)
    End Try
End Sub
This will return the first layer in the map and run the function on it. If you have many layers and need to do this on a specific one, then you'll have to add additional code to loop through all the layers.
SusanneWagner
Hello Ken,
thank you a lot for further help!! Now, it starts in ArcGis and also shows the first field of the table Unluckily after that I receive error message:
I don't know how to translate it correctly from german but it is said that the com-object of type "system._comObject" can't be changed into interface of "ESRI.Arcgis.Geodatabase.IFeatureClass".
May I ask you again if you recognise some other wrong parts in the code above?
Thank you in advance!!
KenBuja
This code works correctly, giving me the two fields with aliases in the dataset that I tested it on. One note, though. This will not show any aliases that you have made to the layer in the map document, only aliases that are in the dataset.
Public Class Button1
  Public Sub New()
  End Sub
        Try
                pFLayer = pLayer
            End If
        End Try
    End Sub
    End Sub
    Shared Sub ShowDistinctFieldAliasNames(pFClass As ESRI.ArcGIS.Geodatabase.IFeatureClass)
        Try
            Dim fields As ESRI.ArcGIS.Geodatabase.IFields = pFClass.Fields
            Dim field As ESRI.ArcGIS.Geodatabase.IField
                    Debug.WriteLine(field.Name & ", " & field.AliasName)
                End If
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Sub Error", Windows.Forms.MessageBoxButtons.OK, Windows.Forms.MessageBoxIcon.Error)
        End Try
    End Sub
End Class
SusanneWagner
Dear Ken,
thank you again!!! You are great!!! The add-in works perfectly!  Thank you!!
KenBuja
