buffer with checkboxes
3001
08-03-2015 11:32 AM
TaN
Hi!
I'm trying to create 4 checkboxes (values- in miles- are 0.5, 1, 1.5, 2). I want to make it so that the values of checkboxes that are checked get inputted as params.distances (for buffers). I've tried for hours and I can't seem to get the dojo checkbox to show up.
When I included 'dijit/form/CheckBox', I followed the example tutorial. Widget.js had the following:
var distances = [];
        var cboxpt5 = new CheckBox({
            value: "0.5",
            checked: false,
            onclick: function(){distances.push(cboxpt5.value);}
        }, "cboxpt5").startup();
in Widget.html, I had:
<input id="cboxpt5" /><label for="cboxpt5">0.5</label>
I kept getting just a text field when I launched the web app, so I figured that somehow, the checkbox form widget.js was not being conveyed to widget.html.
I looked at a code sample of Robert S. and I noticed he used 'jimu/dijit/CheckBox'. But using that module didn't work either. Any ideas? Thank you!
RobertScheitlin__GISP
TA,
  The main issue was including dijits requires _WidgetsInTemplateMixin require and declare in your code.
Here is your code updated:
TA,
