When I try to reclassify my raster into 5 classes using quantiles or other methods, arcgis return a raster with an extra class (775)...
How to solve this problem? can someone help me? I'm using ArcGis 10.3
Solved! Go to Solution.
Solved!
Float Raster --> int Raster --> reclassify
Glad you solved it. However, the Reclassify tool should work on Floating rasters too (without creating additional classes).
Can you include a screen capture of the definition of the classes (the Reclassify tool)?
Solution N°2:
convert 64bit float raster to 32bit float using copy raster
