AnsweredAssumed Answered
Error 001359: Failed to connect to server : ArcGIS server 10.3.1
Question asked by iamlaksh3 on Jul 31, 2015
Latest reply on Mar 23, 2018 by javier.pintos
Hi
I have installed ArcGIS Server 10.3.1 - am unable to publish the services. When i try publishing using Arcmap am getting Error 001359 Failed to connect to ArcGIS server. ArcGIS server configured to HTTP and HTTPS and uses Web adaptor. PublishingTools does not get started, it throws an error . I could able to connect to manager using HTTPS and view services etc,
Service failed to start
  1. System.PublishingTools.GPServer: com.esri.arcgis.discovery.servicelib.AGSException: java.lang.Exception: java.lang.Exception: The server was unable to access the URL 'https://myserver:6443/arcgis/services'. Please check your firewall and security settings. For more information, see the ArcGIS Server help topic Ports used by ArcGIS Server. You can access this topic in the table of contents by navigating to Administering ArcGIS for Server > Securing your ArcGIS Server site > Configuring a secure environment for ArcGIS Server.
ArcGIS server throws error "AGSAdminConnect FAILED."
When I configure HTTP authentiction, publishing service started. I have throughly investigated all data-configure and other config files could not find place a where call "https://myserver:6443/arcgis/services" is made?. Deleted site and recreated everything looks good.
I am not able to start the publishing service and publish any service. Any pointers is highly appreciated.
Outcomes
